Hi All,
After a bit of info, just about to do a service and change out the steering rack......
Does anyone know approx how much PAS fluid the whole system takes?
Also going to change brake fluid but again I'm not sure how much I will need to change the whole lot.
Whilst I'm doing this, I will also change ATF, going to use the drain & refill method a few times over next few weeks rather than the bucket method. Never changed ATF, I take it the drain plug is the one stamped with DII?
Thanks in advance.
Ben
Thanks in advance.
Ben
