auto box brake band adjustment
    this could be the holly grail lol please please please does someone have a pic
    I'm starting to see light at the end of the tunnel
    cheers guys
      Sorry mate i don't but if you get your hand down between the bulkhead and cylinder head, feel along the EGR pipe and just down from the pipe you should be able to feel the earth as it goes to the head.
        cheers mate first job tomorrow then is it a think wire
        cheers
          cheers
          About 3mm thick IIRC.
            thanks mate if i cant see it i will try and find the location of where it attaches at both end and put me own in
            cheers
              Well it won't hurt to have a secondary earth point just in case.
                thinking that myself just have to sus what its connecting to what
                cheers
                  Have a search for the wiring diagram it should show you the earth points but as far as i can tell it earths the engine to body so it should also earth the g/box through that as well, or you could put an earth strap from the g/box to body and have the earth from the head to body as well. Just to cover all the bases then.
                  • #24
                    sounds like a plane going to get 2 earth straps tomorrow and install one from box and one from block
                    cheers mate
                    • #25
                      Some photos here of the earth wires.....
                      http://www.hiluxsurf.co.uk/showthrea...grammar&page=6
                      There's a thicker one coming from the block behind the alternator that goes to the negative terminal on the driver's side battery.
                      • #26
                        thanks bushwhacker think that think one actaully clamps to wing and not battery will sort that tomorrow as well
                        thanks again guys keep them coming got MOT next week and its smoking like a b**ch
                        cheers
                        • #27
                          IIRC there is also an inhibit, that stops the box changing until the fluid is warm. TonyN will be along to put me right.
                          Non intercooled nothing.
                          • #28
                            do you know any more about this as when it has worked always when its been running a while i.e engine on the hotter side
                            cheers
                            • #29
                              Possible coolant temp sensor...I can't remember exactly.
                              • #30
                                Have a read of post #10.............. again.
