I've pulled a surf auto 'box apart and there is nothing to adjust. The clutch band settings are set and locked.
The electrical connections that are part of the loom are speed sensor, solenoids, ATF temp and gear position sensor.
If you can get all gears normally and manually but no overdrive then it's either the ECT ECU or the O/D switch thats at fault.
I have a couple of ECT ECUs here if you want to try them.
once I'm up to speed everything is fine just have to manually shift from L,2,D with smoke (due to over fuel I suspect) to get there until I go up this hill then OK for the rest of the way to work (most of the time)
This is probably a stupid suggestion but here goes! try another throttle position sensor, i'm not convinced it will be but, as has been mentioned in previous threads they do throw up some obscure faults that are a PITA to figure out.
cheers mate do you know where this is situated
I'm trying to establish common triggers that get it working and so far the only one is after a long run or a high revs as if its a blockage
not convinced its a hardware fault based on the interaction
cheers for everyone's comments much appreciated please keep them coming
mmm been looking at that for ages though it was to do with glow plugs for some reason
don't suppose any one local to bury has TPS I could borrow for a quick test
cheers
I have one but i don't know if it's working 100% it was on my old 2.4 which drove fine all gears were as they should be, cover the postage and i'll send it up if it works we'll sort it later if not well nowt lost.
i'll post it hopefully tomorrow we'll sort it when you have money mate it's no big deal i will need your address though.
my email is
let me know when you have my email so i can delete it again.
