Hi Popeye.i guess you,d have to do a load test to see what current your step draws when it has its full weight on it.if you,re using a very small recovery type winch(maybe 2000 t0 4000 lbs pull) then your winch will only be operating at a fraction of its full capacity assuming your missus doesn,t weigh the same as a small car! my sincere apologies if she does!!
I you still think the loading could be an issue then the bulk of that wiring diagram would still be good with just the addition of contactors in line with the feed to the motor so the two switches in the circuit would only ever have control voltage running through rather than load voltage
i,ve never had to buy the other type of switch for making and breaking the earth but would imagine theres various off the shelf versions of it for use in various machinery
the winch (i'll do a sort of write up with pice in the modifications section soon as i can) is a small 2000 lb "cheapo"
