oil pressue sensor?
  • #61
    Originally posted by BAV1 View Post
    only changing it as I have one
    I cant PM how much is it likely to cost to fit a new transmission any idea (not convinced the tranny itself is the issue)
    cheers
    I charge £200 to change a gearbox, but can't speak for local garages near you.
    • #62
      Thanks Tony how much is the box itself likely to cost as this is starting to get expensive already struggling to justify high fuel costs think it may be time to go back to a "normal" car
      • #63
        The box' depends on the breakers in your area, I'm happy to get £100 for my used autoboxes. (not got any ATM before you ask.. )
        • #64
          ta mate
          to do list is running at around £500-£600 so far then looks like a "normal" car
          cheers mate
          • #65
            Jon i found these! don't know if your still going to fix the truck but worth a thought.
            http://www.ebay.co.uk/itm/1108225596...#ht_500wt_1202
            • #66
              thanks mate dont suppose you knowanything about the fitting is it something i can do myself
              cheers again
              • #67
                Best to ask Tony or one of the others that can tell you.
