Have you pressed the O/D button? You only get gearbox codes with it pressed, and ignition on.
oil pressue sensor?
Yup, and obviously TE1 and E1 bridged in diag box, sometimes you struggle to get a connection, but if you're getting engine codes it must be working.
Originally posted by BAV1 View PostHi Tony
just to clarify
lever in park O/D button in and ignition on im sure i did but will go and do it again now 2 secs
cheers4x4toys.co.uk - Keeping you on and off the road...
yup diag port jumpered okOriginally posted by TonyN View PostYup, and obviously TE1 and E1 bridged in diag box, sometimes you struggle to get a connection, but if you're getting engine codes it must be working.
O/D button pushed in and ign on i get 1 engine check light and no O/D codes
O/D button out just solid O/D light
did get 2 engine check light before clearing codes suspect this was an old code though
any ideas mate cheers
thats what i thought but definatley nothing whidh is why i was swapping out TPS as i have read this can throw up weird errorsOriginally posted by TonyN View PostThats odd, with the button in you should at least get the one continuous 'no fault' flash same as the engine one.
same thoughts on earth cables as had a similar problem on an old tuck bur wouldn't go into top gear after Stevo in stockport had it for a service turns out to be the earth strap on back of head
anyone know of a good place to add new earth on both block and box
cheers Jon
has anyone any more ideas
can anyone show me a pic of where I can earth the box and block figures its a quick job and cant hurt
deliberately didn't boot it up that hill this morning and gears stayed broken??
what would symptoms of a blocked oil filter be
cheers guys
Do you mean the engine oil filter? If that's the case go to Toyota and buy a genuine one they aren't much more expensive. as for earthing points as long as the earth cable has good connections, is out of the way of anything hot it should be ok to put wherever you decide (within reason)Originally posted by BAV1 View Posthas anyone any more ideas
cheers guysI'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
cheers mate yeah I meant engine oil filter its due a oil and filter change was going to get done at the end of the month but though a cheap filter may help diags for nowOriginally posted by tonupteabag View PostDo you mean the engine oil filter? If that's the case go to Toyota and buy a genuine one they aren't much more expensive. as for earthing points as long as the earth cable has good connections, is out of the way of anything hot it should be ok to put wherever you decide (within reason)
do you think that battery earth straps would be an over kill
cheers
im getting filter and oil changed next week may do myself if i can find the oil cheap enough (not decided what to put in yet) as would like to see what comes out and what goes inOriginally posted by tonupteabag View PostI would have thought they would be OK. As for a cheap filter don't bother get a decent one, Roughtrax filters are OK as i use these as do quite a few others on here.
was just thinking cheap filter to see if it made any difference
also looking at doing ATF fluid using the bucket method IF i can sus which pipe is which lol
cheersLast edited by BAV1; 23 January 2012, 17:59.
From what i remember the drivers side is the feed from the box and the left is the return. I don't think you will get much cheaper than Roughtrax plus i would use the semi synthetic but that is my own preference Jon, a lot just use mineral oil but each to there own, it's upto you which you think is better suited to your own needs as it were.Originally posted by BAV1 View Postim getting filter and oil changed next week may do myself if i can find the oil cheap enough (not decided what to put in yet) as would like to see what comes out and what goes in
cheers
High oil pressure usually.Originally posted by BAV1 View Postwhat would symptoms of a blocked oil filter be
cheers guys
If the two straps at the front of the engine are ok you probably won't improve matters, it'll be extremely hard to insulate the gearbox from the engine!
If you want to try it just use one of the transfer case to gearbox bolts, then connect it to one of the gearbox crossmember bolts.
What exactly is the issue? Been looking though a million posts and its not clear.4x4toys.co.uk - Keeping you on and off the road...
A cheap filter can be a false economy. I remember an incident on here not too long ago with someone having a cheap filter almost causing serious damage to their engine.Originally posted by BAV1 View Postim getting filter and oil changed next week may do myself if i can find the oil cheap enough (not decided what to put in yet) as would like to see what comes out and what goes in
cheers
I believe it might be the case that cheap filters don't have the valve in them that stops the oil draining straight back into the engine when you switch it off meaning that when you re-start it takes longer for the oil to make it's way around the engine (starting is when most engine wear takes place).
With a gas guzzler like a Surf it's hardly worth trying to save 5 or 10 quid on a cheap filter given that in terms of diesel it's probably only 20 miles worth!
