Originally posted by Rustinho
View Post
oil pressue sensor?
hi guys thanks for all your responses
heres a recap of the problems as it looks like they've got lost sorry guys
**problem 1: truck will not pull away in DRIVE have to drop to low spews out lots of smoke manually going through gears ok but smoke and doesnt like it if im on a hill
booting it up a short steep hill on the way to work seems to get it working again for a while 9 times out of 10
flahing O/D light
WHAT I'VE TRIED
ATF changed 3 times
new air filter
new fuel filter (topped up with redex) and non return valve added
earth strap from alternator moved from wing to - battery teminal
all connectors i could find reseated
cleared code and when diag port jumpered 1 engine check code "normal" and NO O/D codes
levels all ok
**problem 2: no oil pressure on gauge needle far left (for over 12months)
WHAT I'VE TRIED
earthed cable and needle moves to 1/4 (two cables tested)
replaced oil pressure sender
still nothing
levels all ok
would really appriciate any help getting these sorted i know you guys can help me get to the bottom of this
will be fitting TPS when i get chance as I've been told they can throw up wierd errors
cheap filter comment was just for a couple of days to give me an answer as oil and filter being done next week
on another note dont suppose any one has one of these laying about (i know i'm pushing it sorry)Last edited by BAV1; 23 January 2012, 22:30.
well it passed its M.O.T so all that work was worth it
oil and filter changed and much better still having gear probs but at least i know its not oil etc
any more ideas guys
one little problem is that rad is seeping a little from top pinch weld only 2 years old from milners, not impressed have put some radweld type stuff in but if this doesn't work does anyone know if its an easy fix and rough cost
cheers JonLast edited by BAV1; 3 February 2012, 11:00.
its not actually radweld but something similar from the garage they use it a lot apparently (I personally don't like it but better than rad leaking)
how do I solder the Rad and how long is this likely to last
cheers mate off to roughtrax to price one up do you know if they do the hose kit as well may be worth doing everything together
cheers
I have already reached the limit of my knowledge !
If I was doing it my approach would be:
1. Clean off any paint/corrosion etc from around the leak when the system is drained
2. Prepare the surface with a bit of wet and dry making sure that it's clean and dry afterwards
3. Cover the dodgy area with some flux
4. Apply a feck off big soldering iron and when it's nice and warm flow some solder over the area
PS
I've just lied through my teeth - if I was doing it I'd take it to Dr Anglegrinder and say 'Replace that cheap shitty rad please Tony'
