Hi, I fitted a panel type meter with external temperature probe for measuring the air temp. I can't seem to find a location for the sensor that doesn't at some point get affected by engine heat. It has been fitted to the bottom of the ariel mast, behind the passange side indicator and at the moment it is under the same side foot step
.In the locations already tried it picks up the heat either when in traffic of when the truck is moving and the heat is getting drawn under the car. Has anyone fitted anything similar and where did you fit the sensor?
Thanks
Dazza
Thanks
Dazza
