When driving at slow speeds i can hear a rubbing 'voom voom voom' sound. I expect this is because the discs are warped? It happens even without braking though.
I changed the pads recently and the discs did look a bit scored, so i'll changed them along with the pads.
Thing is, the noise is louder when cornering. I'm just wondering why this is, because it's not like the calipers move independently of the discs or anything, so why would the noise be worse with the wheels turned?
If any noises from the front end persist once i've changed the discs and pads, then what else will need checking?
Thanks.
Thanks.
