snorkel group buy?
  • snorkel group buy?
    i've found a company in NZ that do snorkels for the gen2 for £130 plus delivery and will do discount on 5 or more.
    ill be ordering one, so if we can get some more names we can get a decent snorkel for decent money hopefully.
    here are some details:
    An Essential Snorkel is made of Linear low-density polyethylene (LLDPE). Match the filter with a Unifilter and you have the perfect filtration system.
    - Designer styled with no visible bolts or brackets
    - Air ram - low restriction 90% water separation and full water drainage
    - Minimum joint points, snorkel to air box
    - Utilising existing air-cleaner and under bonnet access points
    - Stainless steel clamps and brackets
    - Polyethylene injection moulding for every snorkel
    - One-piece air-ram including grill
    The snorkel kit comes with all the parts you will require including a template.
    www.apmautos.com
    Given that they're 12,000 miles away, have they told you what they want for delivery?
      I know of a outfit in Spain that'll do them for £20 cheaper than that.
      It's in the search box.
        arent the spanish ones fibre glass though?
        www.apmautos.com
          Does it matter?
          They're just for posing 99% of the time.
            I plan on using it for what it's designed for
            www.apmautos.com
              Keep me in the loop, will all depend on costs on top of the £130...
              Still Can't believe I own a Hilux
                I'm wAiting for a reply to find total costs with a 5 person discount. Once I've got it sorted then I'll get some deposits and order them up if there are enough people interested
                www.apmautos.com
                  Possibly interested once the costs are finalised.
                    I'd be interested if costs arent too bad
                    I looked int o the ones from malaysia for about £75- shipping about the same, but I've seen they are plastic and not that great..
                      No doubt, but why is it a problem if they are fibreglass?
                        no flex so easier to crack i guess
                          With the type of lanes I drive, fibreglass wouldn't last 5 minutes, with these ones you get a bit of flex and give before they break, so unless you fall on it or hit something really big it should be fine
                          www.apmautos.com
                            So, what do they look like?...........Website?...... .......
                            " Time wounds all heels ".
                              Maybe a home made one out of some steel drainpipe (or similar) might be the order of the day?
