Originally posted by Dodge
View Post
Roof rack plan, ideas and a couple of questions...
No appologies necessary, Rivnuts are good for basic fixing jobs, but I wouldn't trust them to secure a roof rack to thin sheet metal.Originally posted by MWS View PostMy mistake. I was under the impression that when they were compressed, the shoulder spread out much further than that....... Sorry........
lol @ Vince.
Yeah, its a pain, but not difficult, the plastic push in retainers holding the back half up usually break or stretch unless you're really patient.
You need to remove all trim around doors, handles, seat belt upper bolts, etc....
Try and get the mounts on the lines at the edge of the roof for strength. I've found 'Penny' washers or bigger arn't enough if you plan on sitting directly on the rear mount, it still flexes unless you're really light weight. The next one I do will get quite a big plate on the inside.
If you have a sun roof you're quite restricted up the sides of it, measure carefully when planning where the feet go.4x4toys.co.uk - Keeping you on and off the road...
Tony N / Maverick thread.............Originally posted by Dodge View PostSo, back on track has anyone removed a roof lining?
http://www.hiluxsurf.co.uk/showpost....74&postcount=1
Maybe this too......
http://www.hiluxsurf.co.uk/showpost....70&postcount=1Last edited by MWS; 31 October 2011, 23:30." Time wounds all heels ".
Thanks for that, no sun roof in this one so no worries there.Originally posted by TonyN View Postlol @ Vince.
Just on question, how does a bigger plate on the inside give strength, I understand it would stop the bolt pulling through but not how it would give support, or are you talking about welding it to the underside of the roof?
Thanks for those two.Originally posted by MWS View PostTony N / Maverick thread.............
I want to get the lining out so I can measure from the inside before making a start on fabricating the rack, pick the ideal location for the feet... unless markp2 gets back to me.
I did a little research on rivnuts and similar fixings, the weakness in the plan is the thickness or rather thinness of the roof skin. You can get them strong enough to cope with the weight of a loaded rack if attached to something more substantial than the roof skin, but to do that you'd need to strengthen the underside which mean taking the lining out, then you'd have no need for the rivnuts.
Thanks guys.
Would you prefer to walk over thin ice in high heels or with snow shoes?Originally posted by Dodge View PostThanks for that, no sun roof in this one so no worries there.
Thanks guys.
Eat.Sleep.Surf.Repeat.
Your analogy doesn't make sense, the shoes would be under the ice.Originally posted by shokenore View PostWould you prefer to walk over thin ice in high heels or with snow shoes?
Putting a plate inside to spread the load will stop the bolt pulling through but won't give the roof strength to support the weight of the rack and whatever is on it.
Yeah, good idea. There is strength in the curves at the edge.Originally posted by Thriftyyou could also look to put the roof holes as close to the edge as possible, and if needed angle the uprights inwards a shade.
I'll get the lining out and see where the strength is.
I just did a clamp on one with suckers at the back.
Read this thread http://www.hiluxsurf.co.uk/showthread.php?t=54133
That should help.I've got a plan and it's as hot as my pants!
Nice.Originally posted by lord_flashart View PostI just did a clamp on one with suckers at the back.
That should help.
I was (am) intending to make one and bolt it on as the only expense would be my time and a length of box section.
Really ?how come?Originally posted by Dodge View PostYour analogy doesn't make sense, the shoes would be under the ice.
You need to spread the load of the rack over an area larger than the bolt hole.
The ice is your thin sheet steel roof what would you want to use to spread the load of your weight thin bolts or a nice big plate.
How you do it is up to you.
What would have been a good idea is to have given an idea of how much weight you expect to carry in the roof rack and how much the roof rack itself is going to weigh.Eat.Sleep.Surf.Repeat.
