Hi all, my Hilux Surf 3l td manual had an oil change (from its previous owner) 5000km. ago. I intend to change the oil and filter myself and would value any advice on the type of oil I should use.
The engine is 1KZ-TE (2982) with 88000km and I would be interested to know if this engine is used in any uk models, in which case I could obtain an oil filter (pattern part) from my local supplier.
Are any oil filters particulary recommended, or are they all much the same?
Am I correct in assuming that 5000km is the proper oil change period
Thanks in advance
Jim
Thanks in advance
Jim
