Aluminium Diamond Plate
  • Aluminium Diamond Plate
    Its just shiny chequerplate,anyone know of a supplier,local or not doesnt matter
    How much do you need?
    I'm a custard donut monster
      Jon,how do. I dont need much,have been toying with the idea of covering/replacing the bash plate,extending it back 6" and bringing the front forward and up a tad,like a silly bugger just been out in the drizzle measuring it,about 3x2 would suffice.Probably hoped I might find an offcut locally but no go.Then I could play around with it a bit,Ta
        How much money you got?
        B&Q do Alu chequerplate in sheets, but it aint cheap...
        www.johnthebuilder.info
          is it the really shiny stuff,last time it took the wife ages to get it buffed up nice
            I like the idea of this. Wanted to make the plate bigger since I did body lift. Is this chequerplate stuff strong enough tho?
            www.vidamusic.co.uk
              I have a bit here but it's only about 10" wide x 3' long so not a lot of use to you
                This is their stuff...
                depends how shiny you like it!
                  According to one site in China it is available in about 5 sizes up to 6mm,2,3,4.5,5 and 6,but you had to buy ten ton,anybody got any room in their garage???
                    oooooh shiny
                      Strong enough to cover, nowhere near strong enough as a bash plate.
                      I have angle iron underneath my A Bar cross member... the plate is just for show....
                        So its as thick as a bash plate but doesnt have the inherant strength of a bash plate,is that because its ally
                          Don't know the thicknesses but yes, aluminium is not as strong/stiff as steel so will bend quite easily.
                            I use a Company called Optima Stainless, for Stainless and Ally. They are based in Kings Lynn Norfolk and are good on there prices, I have supplied Bushy and Popeye recently, If you need any more info give me a shout.
                              David,If you know a phone number I would be very grateful,or just the address,Ta,Alan
                              P.S.,just found it thanks,Alan
