Common problem, yet to find the answer
Jack under the lower control arm of the front wheel, as close to the ball joint as you can get it and lift the truck until the wheel clears the ground.Originally posted by Matt.n.p View PostIs there any way to confirm this?
Had it jacked up under the chasis (with the suspension free) gave it a good shake, push pull wobble and everything seemed solid.
Only thing i found was a little play backward and forward (along the same axis as drive shafts) in the front drive shafts. But i thought this to be normal.
Make sure there is no compression in the suspension when you check the ball joint, let the strut extend as far out as it will go.
Look for grease an indication that the boot may be split, if it is grit may have got in to the joint and damaged it.
Move the joint around there should be little if any play.Brian
