From my reading of the yotatech and other US sites, the OME springs for the 90 series LC will give you 3" of lift back and front on the 3rd gen.
These springs are all available in the UK.
This is the list of lift per OME model I have found on more than one site in the US:
Front:
880 1" lift coil for stock weight.
881 2.5" lift coil for stock weight.
883 3" lift coil designed for 100 lbs. additional front weight.
882 3" lift coil designed for 150+ lbs additional front weight.
A top plate spacer can be combined with the 881 coil for a full 3" lift
Rear:
906 2" lift coil
890 3" lift coil
891 3" lift coil designed for additional weight.
Pretty good link HERE
As everyone has already mentioned, anything above 2" is probably going to require a front diff drop, and rear panhard extension as well as potentially sway bar extensions.
Front:
Rear:
906 2" lift coil
890 3" lift coil
