cv help needed. very odd
  • cv help needed. very odd
    hi all,
    my cv started knocking and front axel/drive shaft bounced up and down 3 times on every singl rotation of the wheel. i hand i replaced the cv unit 500 miles befour as the old one was gubbed.
    i have started looking into it again,
    so i stripped off the cv rubbers and span the wheel round.
    what i found was the inner cv bar was hitting the inner cv bearing cup and so when the wheel span the cv bar wound push against the cup forcing the axel to move down wards.
    question, how the hell do i fix it?
    pics to come.
    cheers will
    Did you re-fit the snap ring on the shaft?
      if you meen the one on the outer cv in the hub then yer i did.
        Is your truck lifted? If it is, how is it lifted?
          yer, 2 inch sus lift and 2 inch body lift.
            Yer?
              I hate having to repeat myself, "how is it lifted?"
                2inch longer shocks, torsion bars wound, anti roll bar 2inch drop. 33 tyres
                purty sure thats it.
                  How old are you?
                    If your CV joints are binding (and you have them built up properly) you may have wound the torsion bars up too much. Are the bump stops still there and in good condition?
                      It's also possible that you have too many tyres. I only have 5; 33 does seem quite a lot.
                        You must be close to Apache's dwelling. Might be an idea to ask him to stop round and have a look at the problem.
                        Brian
                          well its been lifted for 3 years now and has always been fine, so i dont see how the torsion bars would suddenly be a problem.
                          33inch tyres
                            How old are you?
                            why?
                              well i still aint fixxed her
                              but i did ragg her around a pay and play off road all of yesterday and just said to my self 'feck it, i dont care if it breaks any more, I WANNA HAVE FUN!!!'.
                              she worked all day, made loads of noise towards the end of the day.
                              pics to come
                              oh, only bad bit was i was on an axel twist and when one of my wheels was in the air, i got out, for some reason nudged the wheel and the wheel moved, alot. each wheel nut was on by 1 turn, oops
