Well done Andy, I can see how Ambo could get mixed up.
Oscilloscope wanted!
Originally posted by Apache View PostI'd think you could pick something up quite cheaply for the sort of things you'll be looking at Vince. You don't need high speed or resolution really.
We have several in our 'junk' room which will eventually be 'recycled' - but when is another matter!
I can wait.
do they mesure in herts like realy small
cant remember i have a red thing layed around never knewn what the fek it is
but its like a screen loads of buttons and stuff to play whith
and it gose up in mhz is that hertz or is it me being all stupid again?am not die lex sick its you that cant read mate
MHz is MegahertzOriginally posted by JUDWAK View Postdo they mesure in herts like realy small
Hz is HertzDo you know that, with a 50 character limit, it's
MHz is like big and bladd brahhhh. Is it connected right...and George, your not stupid...you make me smile.Originally posted by JUDWAK View Postdo they mesure in herts like realy small
and it gose up in mhz is that hertz or is it me being all stupid again?Non intercooled nothing.
Hang on there's a picture missing. Which one is in the photo; a pup or an O-silly-scope?
What I was getting at was the fact that these things need calibrating fairly regularly and this is unlikely to have happened with a privately owned one.
If your not too bothered about accuracy then it should be ok but the dot on the screen may have "burnt in".
There's plenty of virtual ones for sale now that plug into you PC and do the job,
http://www.picotech.com/ultracompact-oscilloscopes.html
failing that:-
http://cgi.ebay.co.uk/Hameg-HM203-7-...item53e61f9bac
Bet it doesn't stay that cheap though.
Got to go I think my new oscilloscope has had a dump in the cellar.湯
the word hertz is the continental word that took over from the british standard of cycles and counts frequency (the No of oscillations per seconds above and below zero) , for instance the 240 mains supply in the uk is operating at a frequency of 50 hertz (cycles) per second, and another instance radio waves are measured in hertz.Originally posted by JUDWAK View Postiam still clueless
Loads of old scopes under £50 on eBay - if you haven't bought one already.
For what you need to do, I doubt you need it calibrated. But I can *probably cal it for you if you don't mind popping up with it.
*depending on what you buy.Cutting steps in the roof of the world
but i still lick the cat
