3ltre front down exhaust question. rattles
  • 3ltre front down exhaust question. rattles
    my front section exhaust rattles like a pig....! it dosent blow just rattles a bit.
    was thinking could it be possible to take it off and take off the heat plates and replace then with exhaust wrap to keep the heat down.
    anyone done this
    anyone done this
    There is a bracket which bolts the exhaust to the gearbox which sometimes works loose.Also check the turbo heat shields aswell as they will sometimes rattle as with the metal plate in the wheel arch
      Mine rattled and it was the bracket just as stormforce said.
      Just loosened it, gave it a nudge and tightened it up again.
      No more rattle.
      Suppose the constant expantion and retraction of the two
      cause wear and then over time the rattle.
      Remember arrows are silent.....................
      Don't forget to tell everyone its indestructable as seen on top gear.......
        Me too, a few adjustments and tightening of bolts and I was sorted!
        I've got a plan and it's as hot as my pants!
          What about the exhaust did you manage to sort that aswell...
