They should change the law so you have to carry warning triangles for situations like this.
Surf gone......but not forgotten
Originally posted by yoshie View PostI will buy the full thing
[/QUOTE]Wishbone They should change the law so you have to carry warning triangles for situations like this[/QUOTE]
Maybe more a common sense thing nowadays to carry Fisrt Aid, Tow rope, Fire extinquisher, Triangle, bulbs, .... oh sorry I got a Truck not a chav charriot !!!!
Jess
"Cos short cuts can cost more in the long run"Last edited by Diezel Weazel; 16 August 2010, 06:29.Buncefield Burner
Originally posted by Surf01 View PostWe have always carried a warning triangle, visibilty vests and torch in the truck, but have never had to use it.
and 1st aid kit
Hi-lift
Fire extinguisher
Food
Water
etc.
etc.
etc.
Had to use the triangle and vests a couple of times now after finding numpties having thrown their new sports cars at lamposts etc.
Originally posted by stormforce View PostI would buy it back and even if you then sold the complete truck as it is you should get money back as a breaker
As long as theres nothing structual damaged then you should be able to repair it cheap enough
Originally posted by TonyN View Postyeah, thats kinda what I ment, speed isn't really the point, if you can't see round the corner, you're relying on luck that nothing is stopped in the road if you're going at any speed.Oh Nana, what's my name?
Originally posted by Bonniebanks View PostYeah, might buy it back. Guy wants the engine for £400 and I think I could get £300 for the brand new tyres and alloyshttps://www.facebook.com/groups/henpals/
friend driving an older fiat panda coming round a corner and friends door open and as he tried stupidly might i add to shut the door he went across the road and hit a transit wrote the panda off and i must admit i was sceptical as to it being repairable as it had taken the left inner/outer wing chassis leg track control arm slam panel headlights bumper and a few other bits it took him a couple of weeks but he had it repaired at the local college in the motor vehicle dept and after lining it up on the jig the chassis was pretty bent on the n/s but after it was put right and sprayed up it looks like new well nearly all the lines are perfect and the car was only worth pennies but it was his first car and he wanted it back on the road so he got it fixed and had it re-tested just to be sure and the car was fine so i wouldn't be too worried with the truck as long as the chassis is fine and straight the panel damage is an easy fix IMHOI'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
