car transporter
    My mate has one like that, it also has a solid bed and sides that can be fitted.
    Ideal for running scrap to the cash man
    i need to board out the centre on mine aswell as i will be wanting to carry pallets on it soon aswell
      If you are talking about the Jimny you can legally tow that behind the 3rd gen with an A frame.
      The jimny basically becomes an unbraked trailer but as it will be under the ton that will be fine.
      I can make you an A Frame to suit for much cheapnes sir
      but a vehicle on an A frame has to be fully road legal aswell now as there are 2 wheels on the road.I bought a dolly for transporting surfs but as they weren't road legal i couldn't use it anymore for surfs
        this is the same trailer as i have got.It weighs 500kg and a max weight of 2600kg's and big enough to take a surf.It is movable with one person and can be loaded while not hitched up to the towing vehicle
        http://cgi.ebay.co.uk/IFOR-WILLIAMS-...item58891cf3b4
        I find it a very good trailer and only weighing 500kg's you forget you are towing it
        Does it only weigh 500kg? Thats good...........My surf and cr@ppy trailer weighs 2700kg and you saw my trailer, it's made out of tin cans.
        If at first you don't succeed.........give up.
          That's got to be up for challenge mate, the A frame turns the car into a trailer surely.
          If I cut the front off it and closed it up I could call it a camping trailer.
          Brian
            Don't think a 2nd gen can tow 2700kg legally.
            Brian
              cant do that anymore Brian
              I looked into it
              EU rules on trailors changed last year
              私のホバークラフト は鰻が一杯です。
                That was 2700kg unladen, so assuming the truck weighs in at 2000kg the trailer must weigh 700kg.
                  Yep which means you can't tow a surf, with a 2nd gen.
                  Where as a 3rd gen is rated to tow 3500kg
                  Brian
                  • #24
                    Might be cheaper for me to buy a landcruiser, although they seem be holding thier prices very well.
