ford excursion backplates
  • ford excursion backplates
    ....anyone got any?
    Non intercooled nothing.
    ....anyone got any?
    yea theres loads at the ford parts centre in daventry.
    www.overfab.uk
      No there's not...failing that, anyone got the rear bearing locknut removal tool, no 205-488...you CANT get the rear hub off without it...and I need the hub off to fit the new backpkates...which I haven't got.
        what does it look like gra???
        www.overfab.uk
          this any good gra.
          http://reviews.ebay.com/Ford-Explore...00000002672288
          www.overfab.uk
            It looks like a socket with 4 lugs on it mark. I do believe it's also sized at 78mm...actually it's sized at something like 3 and a bit inches...damm Yankee imperialism.
              Sadly not mate. The other excursion was easy. Just a big nut, and I used a box spanner. This one is the biggest available( the v 10 ) with a chuffin great Dana axle. It's COMPLETELY different to an explored or f250...even the f350, and that's a big mutha. It needs to locate the four lugs into the appropriate holes, and at the same tine press the sprung loaded under cap away. The only way to do it, is with the relevant ford service tool. I did order it today...won't bd here till Friday though.
                i was just about to say ive found one but its too small.im still looking hang on.
                www.overfab.uk
                  I'm hanging....
                    this it?
                    http://www.partsmike.com/store/store...on=show_detail
                    www.overfab.uk
                      ah youve got the ratchet type hubs.
                      www.overfab.uk
                        Nooooo....,
                          That's cos it's got the ratchet type hubs...
                            ...AND....the calipers ( there are four...yes four) on each wheel are all 3 piston variants. These calipers are absolute gits to get off. They need to cone off as the parking brakeshoes are interior to the drum...it's a combined disc/ drum affair. Absolutely terrible design...but it's what it is and it's mot time shortly...
                              So these companies that start up these limo businesses using Yank tanks, never think before hand that one day they might need repairing???
