ford excursion backplates
  • #16
    The man in charge of this lot, and I quote
    'cannot see the point of servicing and maintainence...waste of money"
    but then again he's a total ar$e.
    Non intercooled nothing.
    • #17
      He sounds it .
      Neal
      • #18
        Graham would a 3" tube notched to make the lugs do the trick?
        I speak from a position of absolutely no knowledge
        Brian
        • #19
          graham would a 3" tube notched to make the lugs do the trick?
          I speak from a position of absolutely being able to bodge just about anything i can think of
          Alan
          • #20
            It looks like a socket with 4 lugs on it mark. I do believe it's also sized at 78mm...actually it's sized at something like 3 and a bit inches...damm Yankee imperialism.
            Hi mate,
            Have you looked at Snap-on (ouch!! from your wallet).
            http://buy1.snapon.com/catalog/tools...e=snapon-store
            Hope this helps,
            Gman.
            If it aint broke, keep goin' till it is.
            • #21
              he not a yorkshire guy in a suit with a little goaty (limo franchase owner)
              if it is yes he is an ars3
              • #22
                Originally posted by GRASSMAN View Post
                Hi mate,
                Hope this helps,
                Gman.
                Fuc that, tube notched to suit and weld a socket to it, or a drilled with a bar through for turning it. Bodge tastic
                Brian
                • #23
                  I refer to my earlier post ............
                  Alan
                  • #24
                    lol I never noticed you had changed my text in the quote
                    Brian
                    • #25
                      bollix to all of it try a big hammer and a brass drift.
                      www.overfab.uk
                      • #26
                        I'd lke to thank you all for your constructive comments...and George for just turning up.
                        To brian and alan... Triedthe 3" tube...the lugs I cut into it just bent, as the fcuker is done ip so tight. Only a proper tool will shift it.
                        Gman...nice link...but I can't afford to sell a kidney for a socket
                        and stein...go stand in thf corner...drift it out indeed.
                        • #27
                          Bung it into a garage, make him spend some money on it and save you the grief and hassle .
                          Neal
                          • #28
                            I am the garage.....
                            Anyhow, i made some instead, out of some blanks. Right pigf of a job, cos i aint got the hub socket...but its better than jeremy kyle....
