Originally posted by Albannach
View Post
2" front diff drop blocks
Originally posted by dieselboy View PostThe upper control arm is very close if not touching the upper rubber bump stop. I didn't know this until the other day, and have no time / means to lower the truck or trim the bump stop for Avalanche.Cutting steps in the roof of the world
Originally posted by Apache View PostOooh, more on bump stops. Be careful, as the bump stops stop the suspension drooping so much that the CVs bind and blow themselves to bits - just the sort of injury you could do at a pay and play site...
With the diff lowered the CV angles is just like how it was when the torsion bars were wound up on my SSRG. Just a slight angle downward. Avalanche will test it I suppose.Last edited by dieselboy; 28 July 2010, 23:22.Oh Nana, what's my name?
Originally posted by dieselboy View PostAlready done it! Sortof.. Thanks for the warning. I'm hoping that with the diff being lowered it would be okay. Suppose if it breaks thats when the mass drinking starts
With a diff drop, the UJs will probably be OK - you're diff might take a bit of a beating if you catch a big rock though!Cutting steps in the roof of the world
I speak from experience. Wishbone spacers fitted, bumpstop cut down. Didn't have diff drop as I agree with Yoshie, its kind of pointless if your lift is for ground clearance and not for appearance.
Front jacked up with sus at full droop, there was definite binding, and offroading I experienced pinch holes of inner CV boots in 3 equally spaced places. Replacing the bumpstops with new ones stopped it happening and saved my CVs.Cutting steps in the roof of the world
Originally posted by dieselboy View PostAs I have found!
Do you know much about this circlip? I think it's off! We put a new shaft in tonight and we were rushed - I could see the circlip stil in there so I held it with a finger whilst we pushed the shaft through.Do you know that, with a 50 character limit, it's
Originally posted by Apache View PostYou can check by jacking up the truck at the front and turning the front wheels by hand when the sus is at max droop. If your wheel turns with a clunking, you're in trouble. If it wont turn more than about 1/3rd of a turn, you're in BIG trouble
When I first did it it turned without noise but on the lane there was the nasty CV feck noiseOh Nana, what's my name?
Originally posted by Apache View PostI was referring to Dieselboy's post. He has / is going to. Was just pointing out it can be dodgy to do so.Oh Nana, what's my name?
