next 2" lift on the way
  • next 2" lift on the way
    wahoo, just been told by my mate he can make me my balljoint spacers as individual plates from 10mm steel for £6.50 per plate
    so i will need 10 plates to do a 2" lift (5 per side) so £65 for 10 plates
    should be done for next week when im having the bearing etc sorted by a mate
    coooooooooool then ill have my 6" overall lift, just need some 33's now and im sorted
    Might be a silly question, but do you actually need 2" of spacer to lift the suspension 2" What with the spacer being loads closer to the pivot point than the wheel is...?
    it's in me shed, mate.
      6" eh? Can you run thorugh what setup you have and what other things you'll need to mod to get 6"?
      I've got a plan and it's as hot as my pants!
        erm yup
        you space the balljoint down 2" so it gives 2" of lift,
        i think lol
          yeah no problem
          currently i am running a 2" body lift using 2" lift blocks, and i have 2" coil spacers fitted to the rear springs withe the front torsion bars wound up 2 " on the front so overall i have 4" so far above standard
          the 2" spacers will be fitted to the front and the diff will be dropped to level out the joints a bit
          the rear will have +2" springs fitted to my 2" spacers and new +2" shocks fitted , brake lines will be extended to allow the extra height
          jobs a goodun as they say ,
          so overall ill have my 6" lift
          # then with 33's fitted ill have another overall lift of 1" as im currently running 31's
          cant wait
            steve just make sure they look nothing like my plates,they are patented.
            www.overfab.uk
              Originally posted by animal View Post
              yeah no problem
              cant wait
              Won't fitting 4" over springs make the offside upper control arm sit on the fuel tank ?
                no worries matey, they look like the big thick plates but in smaller chunks so i can tune it how i want ,
                would never dream of copying yours mate
