earth magnets
  • osmosis
    any one know owt about osmosis?
    its part of this projected
    i have been a bit ill so i made my self do a few easyer parts of this project
    i got a few samples of what it is iam looking for in the soil
    and broke the sample down till it was just about dissolved in water
    through a set of filters starting from 50 micron down to around 5 micron
    and solidification with some good results
    i think i can pull this off
    now iam thinking i need to go the whole way by using osmosis
    to see what else is left in the water the TDS is above tap water so there is something left in the water
    but osmosis filters cost loads any one know why?
    i only want to test the crap left in the filter to see whats left behind
    i have to test this the whole way
    i got to just to make sure the waters not polluted after osmosis too
    • isn't that an ozzie album?
      Are you trying to make gold?
      • I know LOTS about osmosis and semi permeable membranes. You just gotta make sure your media is thick enough to stop plaque/slime mould adhesion and watch your tmp's
        Non intercooled nothing.
        • Oh.....and what you want to do George...it doesn't work.
          • it works
            i just want to know if it pollutes too
            i need to make the water the same has it was before i started or cleaner
            osmosis dont take out pollutents only the minrels
            i cant test it perfect with what i have here
            i can test it enoght to know its still got minrels in the water that was not there when i started
            and if this dont work
            so what
            it can do plenty more so losing one thing aint that bad
            tmps ohh yes i'll keep mi eye on it when i go out like
            • Hi George...it won't work. It's been tried through the ages. To achieve decent and proper filterability, you will need a few hundred square meters of osmotic membrane. This stuff is mega bucks, something like £100 a square foot. You also need At least twice as much water as a ratio to membrane surface area. You need to aerate, you need to filter and you need to remove captured minerals with acid. You need the luck of old nick to find anything....but keep on trying George...good luck.
              Oh btw, you will have a high level of pollutant in your end liqours.
              • Maybe George is just after the 'end lickers'?
                • Originally posted by Apache View Post
                  Maybe George is just a window licker
                  There...fixed it for you andy.
                  • Originally posted by gwh200 View Post
                    i understand what ya saying iam only doing this small scale just yet
                    but to do it on a big scale i need space
                    that means i have to move it to bigger yard with lots of room with a run off that deals with pollutants
                    mi dads got one but he is useing it for fencing dip tho but not in winter
                    i still think its worth a shot
                    looks like i may need to dig out some of mi collectables to flog for funds
                    its keeps skinting me dose this
                      Maybe George is just after the 'window licker'?
                      maybe iam just a licker
                      so mi tash stinks i mean thinks
                      • so....
                        are we ready to divulge what the cunning plan is yet or is it still in the experiment stage?
                        My Surf eats knuckles for breakfast!
                        • thanks for asking
                          most experiments i needed to do are done
                          2 of them work 1 works but to do it on a large scale is something that i will never aford
                          iam also working on 1 different experiment thats part of this projected
                          it involves looking at geophysics the costly part
                          the 1 thats not ever going to be afordable or cost efective works like this
                          soil gets turned and broken down has this happends
                          i use a magnetic field to remove some elements
                          i broke these down by useing water
                          different sized filters
                          barrels for solidification
                          and a lot of patiences
                          i did managed to separate the elements
                          but to do this on a scale were i could help farmers by putting an end to crop rotation is more than i could ever do or aford to do
                          but there is 2 things i can still use my idea for
                          metal detecting
                          meteorite hunting
                          these are my hobbies anyway
                          so iam still buzzing with the idea
                          add that to some good geophys scans that iam looking into
                          it gives me a 3d image of whats under ground and i can tell what metal it is
                          the elcetromagnet cleans up before the scan and picks up any meteorite thats around too
                          once all this is made
                          i will be hopefully be able to hire me and the truck out to a very well known organisation
                          iam just very skint at the moment and makeing fitting these things to my truck is going to cost a fair amount of loot
                          plus my truck it needs some tlc on the front drive train then its all just about new from back to front
                          cant wait to get it back on the road coz it drives like new too
                          but i iz saving pennys so i cant have nowt
                          • sounds like a plan to me.
                            when do we get a gawp at this device then?
                            • Originally posted by che2318 View Post
                              end of this year hopfully
                              • you SURE you're not chucking good money after bad?
                                Do you have a real market for yout finished truck (i.e. is anyone gonna hire you?)?
                                Or is it basically you having a great time building a big, fat, boyz toy, and to hell with whether it works / makes your fortune etc!!
                                I'd love to have some time to do some mad stuff, you lucky, lucky b4stard!!
