I want to flush the current coolant and replace it with some decent stuff this coming weekend. I don't know what is in there right now, but understand you cannot mix the coolants? I was thinking of buying this from roughtrax - http://www.roughtrax4x4.com/?doc=16&cid=164&vid=1270
Whats the difference between the red and green? I just have blue in mine where it has been topped up just now.
Also what's the best way to flush the current coolant out? I was just going to remove the top hose and use a garden hose to pump water in, and use the drain plug on the rad to drain the water out, but how do I flush the heater matrixes? (Matri?)
What is going to happen if I don't managed to clear all of the current coolant (unknowingly) and then put brand new red coolant in?
