Even fitting 6mm spacers will eliminate the need to grind your 16" wheels so bolting 30mm spacers will give you plenty of room. I was considering doing the same. I've also decided to fit a new set of longer Goodridge stainless steel hoses while I'm at it.
I picked up a set of pads to suit the 2006 Tundra calipers, they're Toyota parts and are the same as some Landcruiser ones. The Toyota part number for them is 04465-35290.
