My poor Surf!!
  • My poor Surf!!
    Hello Surfers,
    I've only had my surf for 1 week but decided to go to Devils Pit today.
    I mainly went just to have a look at the place and test out my 4X4 system.
    I didnt get too carried away as i've never owned a 4X4 or been off road before.
    I had a great time sliding about in the mud and water, i've only got road tyres on so took it easy.
    The thing is, my surf is now covered in a chalky mud, and so is my engine and radiator!!
    Will it be ok to use a jet washer on the engine, or just the radiator?
    It will take a life-time to clean it otherwise,
    Thanks for any info, Stuart.
    Originally posted by Stuart Lampard View Post
    Hello Surfers,
    Devils pit mud sticks like sh*t to a blanket
    You can use the jet washer on the engine but keep the engine running and try not to get the electrics to wet. The rad you need to be careful of because the power of the jet washer will bend the fins, you would be better off using your garden hose and yes it will take along time to get it clean
    I'm a custard donut monster
      info on rad cleaning.
      http://www.ehow.com/how_4508137_clea...aturn-vue.html
      Alan
        Thanks for the info, fellow surfers.
        I will use the garden hose and small brush.
        I suppose it will be my punishment for having so much fun!!
        The surf looks good with mud all over it, like a real mans car!!
          get yourself to the avalanche weekend Stuart and meet up with a load of us and it should be a good weekend.
          Replied to your email aswell
            If I have been in mud, I put the garden sprinkler underneath the truck for a coupla hours. It helps.
            Sent from the iPad you "lost"
              Biosurf did a good write-up on here about cleaning rads ......search for it
                thats a ###### brilliant idea.
                私のホバークラフト は鰻が一杯です。
                  I found Biosurf's rad cleaning write-up, good idea to make the pipe with holes in, and attach it to your hose so you could poke it down and get at the whole radiator! The man is a genius. I wonder if he has pattened the idea?
                    Salisbury plain mud is like concrete ........ he learnt from the best
