Hiya - can anybody help with a small anoying problem that has started happening with my desktop PC.
Every now and then, when pc goes into standby mode or is powered off - it will not restart - I just get a blue screen with a message to the effect that I have done something wrong or something is wrong inside, with the following error code....
**STOP: 0x0000007e(0x0000005,0xb919962 5,0xba5171f0,0xba516eec)
no other message or help appears. I've tried googling the error code to no avail.
the strange thing is, if i leave the power turned off for say 5-6 hours - it will restart without any hiccups.
I thought it maybe a cooling concern and have stripped casing, cleaned out all dust from fans etc and checked all connections - no effect. Have also changed the cmos battery.
prior to this happening i have not installed nor removed any hard/software.
if i only knew what these error codes meant - or how to look them up would be a good starting point.
any ideas before i bin it a buy a new system???
