air-con compressor
  • air-con compressor
    i think i've read somewhere that you can use your air-con compressor as an air compressor if you fit an air tank of some kind, but car'nt remember where i read it or if i'm going mad lol,
    as any body else heard or done this mod i'm going to remove my air con this week and if this is possible i'll keep the compressor but if not i'll bin the lot.
    cheers
    when the sh*t hits the fan greet the reaper with a smile
    yeah, google it, the yanks and ozzies have done lots.
    You sometimes has issues with needing oil to stop it seizing up. most people used some kind of volvo compressor that seems to run happily without oil
    The surf pump has metal vanes, so wouldn't like to be dry for long, you'd need to add oil then remove it before the air tank.
      cool thought i had read it somewhere will look into it as i've got a small compressor tank and gauges here so should have all the bits to make it work cheers
        cheers
        Just a word of caution to bear in mind. As we all know, air con systems have refrigerant gases in. Most Surfs use R134A. You are supposed to take your vehicle to an authorised air con specialist to recover the refrigerant gases, and the Ester oil before removing your air con unit.
        The penalties for not doing so are very heavy indeed! Up to £50,000 fine and/or 6 months prison term!
        Don't say you haven't been told about this!
        Regards.
          mines empty anyway, the pipes have been disconnected so nowt left in there anymore
            Check the files at the top, click files and it'll open up to several choices, there's a writ up on the old air con thing there, or fitting an aftermarket comp/tank by me on matt's site
            http://forums.bauchan.org/portal/index.php
              Not even any oil?
              (Refrigerant is absorbed into the oil.)
              Don't mean to harp on, just concerned. I'll shut up now!
              Regards.
