is the surf head problem something that only affects imported cars .did surf/4runners that were ment for england have the same problem or did toyota fcuk up on all surf/4runners the world over
head trouble no not mine .
the head thing. did it not start showing up in most engines when they were like 8 years plus old???
not really a biggy is it. plus there's enough good 2.4's out there because they've been serviced well enough to never overheat.
bye now.i swear, it was like that when i got here...
They are, but it's probably to do with poor maintenance in their previous life than poor head design like the 2.4.Originally posted by Albannach View PostI thought the 3.0L heads were cracking too? What is their failure mode?
3.0 engines do seem to suffer more with gasket failure though rather than just the heads cracking all the time.
That does seem to be the common denominator. I wonder if the previously overheated 3.0l Surfs will be next?Originally posted by logey79 View Postnot really a biggy is it. plus there's enough good 2.4's out there because they've been serviced well enough to never overheat.Do you know that, with a 50 character limit, it's
Ah, I stand corected. Didn't realise the gaskets failed too.Originally posted by BUSHWHACKER View PostThey are, but it's probably to do with poor maintenance in their previous life than poor head design like the 2.4.
3.0 engines do seem to suffer more with gasket failure though rather than just the heads cracking all the time.Do you know that, with a 50 character limit, it's
