vehicle ln130 tde.
Can anyone help with some information please, I have had lots of problems with cold starting issues and I think I have tracked it down to coolant sensor for ecu, what I need to know is what voltage is being supplied to the coolant sensor(thermistor) at present i have 0v to sensor, but when i done the same test on air intake sensor it was constant supply of 5v, which leads me to think there is an output fault on ecu causing an overfuelling problem,(missing, poor idle and black smoke).
could some one be kind enough to test their vehicle and check output voltage from plug that goes into the sensor please.
Test and repairs i have already tried to overcome problems.
1. Rebuilt head & skimmed/ reset valves etc...
2. Honed bores/ new rings etc (compression 550psi on all cylinders)...
3. Re-con injectors...
4. New glow plugs...
5. Manual switch to glow plugs holds on for 12secs at 11.5v,(this helps but not cured original fault)...
Any advice appreciated.
