gear box truble
  • gear box truble
    haz enyone got a automatic gear box for a 1994 3.0 kzn130 surf as mine is playin up and no one seems to beable to help me with mine keep popin out of first and then the o/d light starts flashing , thanks iceman
    If its just the gearbox and not the trans box with it then i have one here if you want it.The trans box is still on it but a part at the back is broken but the gearbox should still be ok tho
      Popping out of first? on an auto??
      Explain more.
        has the atf been checked right and or changed first to see if that solves the problem.
          Explain more.
          wen you stop it pops out and wont select first drop in to low to set off and then bak to drive its fine till next time but if you just try setting off its like its in third , then the o/d light starts flashilg
            As Richard said, the transmission fluid needs checking first as it is the cause of nearly all auto transmission problems.
            Check the level with the engine running by the way in case you didn't know.
              been done and serviced
                Was it working properly before the service ?
                Was it serviced by a reputable company/person ?
                It's not that simple to replace all the ATF in a Surf - for the sake of 5 minutes of your time check the ATF level and condition. If you're not familiar with the EXACT procedure do a search on the forum
                  As others have said, check the fluid level.
                  Make sure that the engine and gearbox are up to temperature and then with the handbrake on and your foot on the foot brake move the gear lever slowly back and forth through the different positions. Then put it in Park with the engine still running and get out and check the Hot level mark.
                  Mine WAS a 150 bhp V6 and ran on PETROL
                    think so my dad got it done wen he got it and its had new oil in since and its been checked like u sed ,thourgh the box but still playin up ,, my dad haz sold me a dud
                      The next step is to carry out the diagnostics test and count the number of flashes.
                        not that simple been to 4 places and toyota and even steveo at the engin com at stokport ,carnt help the eng check light is not on just the o/d light but as its old its the gear box ecu not the cars ecu .. its realy doin my head in now as no one haz had this prob b4 , cos dont want to fork out 4 a new box if its just a senser or a dodgy plug or pipe
                          The engine check light is for the engine, the O/D light flashing is for the transmission faults.
                          http://toyotasurf.asn.au/techsite/do...odiagnosis.pdf
                          I can't belive Stevo didn't know this.
                            just printed the autodiagnosis off and its complett blar blar to me so will pass it on to my local garage to look at or to my local automatic box repair centre but i must just prepare my self for a long painfull prosess and £££££££££ i expett but wen i get to the bottom off this i will let the world no ha ha
                              All you need is a paperclip, straighten it out and poke it into the terminals as shown in the diagram, make sure the overdrive button is off, switch on ignition and count how many times the O/D light flashes.
                              It will flash a number of times, then go off for a couple of seconds and flash another number of times. Just make a note of the first amount off flashes then after the pause, the second amount of flashes. The two numbers you have will be the fault code. Just look at the codes list to see what you have.
                              It'll save you loads of cash/time and we'll take it from there.
