bottom hose
  • bottom hose
    found that the bottom hose on the truck is seeping coolant when cold, put a new clip on but cant seem to tighten up enough to stop it. So, i think that the hose has had it. New one should be here today from Roughtrax. Any comments welcome
    SWIFT AND BOLD
    Is it wrong that the thread title made me laugh?
      it could be a little concerning
      SWIFT AND BOLD
        Errmmm
        YES..
        My other cars a QUAD
        (sv1000spilot on surf forums)
          Not sure about the 3.0 but on the 2.4 you have to drop the air con rad to get at the hose not a bad job to do though, its just the coolant refill/flush etc bit of a pain.....
            Make sure when you change the hose you clean the bottom pipe of the radiator off as well.
              thanks guys the air con rad is in front of the main rad so no drama there, i will have to wait till the wife gets home tonight to do it, it shouldnot take too long
              SWIFT AND BOLD
                Also make sure the jubilee clips are the wider type, and that you've get plenty of anti-freeze ready to re-fil the system.
                  3.0 L a bit different then, Is the wife fixing it for you then ? Wow hang onto her mate !
                    It's a 3rd gen - only women are allowed to work on them.....
                      The wife has taken it it UNI as her car was in for a break problem, so she will be in about 5 ish which gives me a small amount of time before it gets dark to change it over.
                      SWIFT AND BOLD
                        When you refill the system with coolant, remember to pour it in slowly. You'll minimise the probability of airlocks that way. Also fill the expansion bottle about half full with coolant. Any surplus will just get shoved out if needed, but you will have surplus in there to compensate for any air which may exit through the expansion system.
                          Great stuff, thanks Matt
                          SWIFT AND BOLD
                            or rather than matts way,do it the proper way refill cooling sytem,not overfilling the expansion tank,run engine with rad cap off,keep goin until normal running temp,top up as required,make sure u get heat from heater then replace cap
                              Water expands as it warms. It will just push coolant out of the cap area using that method, unless there are vast airlocks in there which happen to escape via the open outlet.
