Would it fit ?
  • Would it fit ?
    would a tjm bumper for a shogun fit a 2nd gen surf without to much hassle
    TIA
    I NEEED MUD.....and Welsh spring water!!!
    No, not without a lot of cutting and welding to the mounting brackets.
      If you can alter it ....if it's a steel one it will be easier to weld a alloy one will be harder to modify
      you can make a landy one fit if you have the equipment and ability to do it
      but a mittsi one will not fit on as it is
        thanks very much bushwacker appreciated for your time
          Get a tirfor .....then you can use it from any angle
            which landy 1 ian theres so many and they all break down it must be the only good bit on them
              tirfor ? na to lazy thats why i got an auto
                tirfor ?
                It's a ratchet winchy thing
                Sent from the iPad you "lost"
                  http://cgi.ebay.co.uk/TIRFOR-TU16_W0...d=p3286.c0.m14
                    Sorry ian but which landy bumper will go on the surf PPPPPPPPPPwease
                      You will still need to alter the fixing points so a angle grinder and welder is needed ........ if you are able to do so one of the tubular ones will fit as supersurf has done it
                        do you know which model disco 90 110 range ?
