Originally posted by Albannach
View Post
Track rod ends quickie
Originally posted by mickyd View Postand the reason for grub screws and not grease nipples on the inners, is that the grease nipples foul the bodywork, when you fit the TRE's watch how close the TRE's come to the bodywork when turning the steering, mm's in it!Do you know that, with a 50 character limit, it's
Originally posted by stormforce View Posti left mine on the ground when i did mine but it will help a bit by having the wheels off the ground thoOriginally posted by KERRSURF View PostI'd jack it up and take the wheel off.
Getting those adjuster tubes off almost did do me in, btw.
Now for the tasteless tat moment. Seeing as I did the shocks in luminous yellow, seemed a crying shame to pop a bog standard white steering damper on there. So...................
