I fitted the procomp one when I got my 33's, stopped pothole shake.
Track rod ends quickie
Originally posted by KERRSURF View PostPic of damper installed.
Originally posted by KERRSURF View PostI fitted the procomp one when I got my 33's, stopped pothole shake.Making the steering less sensitive to deviations is the main part I'm after, and it does sound like it'll sort that out.
Originally posted by MattF View PostJust to double check on the track rod ends, they are pre-greased, are they not? They don't need any prep'ing or suchlike before being fitted?
Just noticed Duane's reply. I've never seen an ungreased TRE (or Balljoint) but they seem to exist.
Like Alan said, more grease won't do any harm.Last edited by Albannach; 14 August 2009, 16:04.Do you know that, with a 50 character limit, it's
Just been looking at them and another question, (or two).The inners have a grub screw on the rear of the housing. Will that be a blanking plug for a nipple fitting? Outers don't have that grub screw, so....., what's the best method to get one of the spring clips off without damaging the boot?
Yep, the grub screw can be replaced with a grease nipple. Is the clip holdong the boot one of the really tight circular spring things? If so, it should roll off downwards (away from the taper). The one without the nipple should be OK for grease though, I'd be surprised if it's dry.Do you know that, with a 50 character limit, it's
Originally posted by Albannach View PostYep, the grub screw can be replaced with a grease nipple.
Originally posted by Albannach View PostIs the clip holdong the boot one of the really tight circular spring things? If so, it should roll off downwards (away from the taper). The one without the nipple should be OK for grease though, I'd be surprised if it's dry.
