Easy way to check rear brake pipe.
  • Easy way to check rear brake pipe.
    Found a very easy way to check the rear brake pipes, if you lift the rear seat behind drivers side, then pull the carpet up there is a plate there held by 3 phillips screws, remove this and you can see the brake pipe behind the fuel tank, mines nice and clean with no corrosion.
    www.furryfriendsinneed.com
    So is mine!
      Hi Popeye, wish the underneath of mine was that clean, , the wife has promised me a roundtoit for christmass, can't wait.
        Worst parts cleaning the bottom, then just spray coat after coat,
        forgive my ignorance but wots a roundtoit?
          there are to help you do those jobs that you cant do until you get one!
          "i'll do that when i get around to it"
            Right! It 's someone to do it for ya then
              Thats a great tip Greecy! Will have a look this week.
                Thanks Apache, i only found it by accident, Bushwhacker said he thought that plate gave access to the sender unit and pickup for the tank, but they are nowhere near it, saw the brake pipe grabbed me torch and had a good look, you can see it all against the chassis rail and if you have small hands like me, ps if they get stuck, i wasn't there, didn't suggest it and know nothing about anything.
                Hi Popeye, if you need a ROUNDTOIT, i will have a spare about the 3 or 4th of January.
                  I 2nd that. More work to do now
                    Here's a few examples of a "ROUND TUIT"
                    http://www.passco.com/tuit.htm
                    .....and one for those that didn't get a Round Tuit.
                      Do i really need one? thats the question, i am married
                        Hi Popeye, if your wife has a lost of jobs that need doing, and the list gets bigger, you will need a ROUNDTOIT, or at the very least an ok HONEY I WILL GET AROUNDTOIT. These can be exchanged for play time with your toys,. Try not to give to many ROUNDTOITS out, as you will run out of bargaining power.
                          Takes me ages to do jobs around the house, i can alway's find summat better to do, they dont understand one has to get in the right frame of mind for these things, (our four kids were spaced out over a long period)
