ok finally took the plunge,got one,a linksys wrt54gs,first i struggled to get it to work wired,rang help line,they explained how cack virgin is and got it working,fine lovely,ok so now try connecting wireless to the ps3,did setting wep key etc,found ip,lovely,did connection test,lost ip,tried setting again,same result,back to computer,and just saw a bubble go down saying sumthing bout trying to share ip connection???no internet,reset computer,that works now but no ip address when i try to set up on ps3?heeeeelp
wireless router
its nice to here that this 5h1t gives others trouble and not just me it wouldnt be allowed if it was a car or a washing machine but as its to do with computers its ok to pi55 people about technology should be very simple for the user it should do its thing almost by its self but no its something for a pc so its ok to fcuk us about
I'm certain when I set up my sons I let the ps3 search for my router/wireless signal selected the one it was, entered the 8 digit wpa and on it went, I dont think you need share the connection as that would pass through the comp, you just need a direct to router connection, ip is possibly 192.168.1.0, cant remember the linksys off hand but its on the base anyway. H
Hi,what hazzo says is correct, you do not want to share connection with your computer, let the ps3 do the work for you, make sure you password protect your wireless router, so only you and not anyone can connect through you wireless connection,, most laptops now have wireless capabilities built in, and if your connection is not secure, they can use your connection and ip to go online,www.furryfriendsinneed.com
Originally posted by Hazzo View PostI'm certain when I set up my sons I let the ps3 search for my router/wireless signal selected the one it was, entered the 8 digit wpa and on it went, I dont think you need share the connection as that would pass through the comp, you just need a direct to router connection, ip is possibly 192.168.1.0, cant remember the linksys off hand but its on the base anyway. H
Originally posted by breakdowntruck2 View Postdid the above but it wont let both "on"at once
Or make sure router is on the right network mode - mixed is best
I also had to open ports for the xbox 360 but not sure if any need opening for the ps3?Last edited by Trinity; 4 May 2009, 19:44.Save earth...it's the only planet with chocolate
Originally posted by breakdowntruck2 View Postyes without a shadow of a doubt,pc is wired via ethernet,ps3 wireless
They need to be using different ip addresses
e.g - pc 192.168.1.2 - ps3 192.168.1.3Save earth...it's the only planet with chocolate
Originally posted by breakdowntruck2 View Postok finally took the plunge,got one,a linksys wrt54gs,first i struggled to get it to work wired,rang help line,they explained how cack virgin is and got it working,fine lovely,ok so now try connecting wireless to the ps3,did setting wep key etc,found ip,lovely,did connection test,lost ip,tried setting again,same result,back to computer,and just saw a bubble go down saying sumthing bout trying to share ip connection???no internet,reset computer,that works now but no ip address when i try to set up on ps3?heeeeelpSWIFT AND BOLD
Originally posted by breakdowntruck2 View Postnope its other side of room,any way to change the wireless ip?
If you go into the router page in the pc - have a look at the wireless encryption - is it on tkip or aes? - it should be tkipSave earth...it's the only planet with chocolate
