wireless router
  • #31
    Switch everything off, disconnect all, press computer start button on/off a couple of times, reset router using little button on the back. Plug in the comp and start the router, let it boot fully till your net connection is on, fire up the pc, then open browser and configure your connection in the router s/ware for the comp, do the security bit, (wpa pre shared key) etc till your comp is connected, keep the router at the mixed setting and enabled for dhcp. Once its running then go back to the ps3 and do the search wireless bit, enter password and connect bit again.
    These thing like everything to be done in order so if there's problems its best to start at the beginning, do everything I've said here, my first router was linksys and in my opinion they're better than the netgear or belkin but are a bit unpredictable on set up but once you know the ins n outs they're the biz.
    report back whether or no you get it on this time. H
    • #32
      ok i can now get both online cheers,but i can go into playstation network,market square(wot a bizaar experience that is!)but every game i try requires a dload to run online,they get to 5% and lose connection
      • #33
        I'd connect it wired for downloads if you can (cant remember) its faster and won't lose connection, glad its working for you though. H
