Originally posted by surfenstein
View Post
Anyone doing a lexsurf conversion
The one up here is already in a scrappy, he won't sell the whole car in one piece, but he will give me whatever I want from it for £450. Engine, box, tanks, LPG conversion, instrument cluster, all the wiring - whatever I want. No storage or disposal issues and no problem with lifting anything either...Originally posted by TonyN View PostSave you getting rid of the rest of the car if you're short of space. looks like all the bits you need are there.Do you know that, with a 50 character limit, it's
It's has multi-valve heads and four overhead camshafts, so is built for high rpms rather than torque. Some tuners have had these V8s (early nineties versions with much thicker con rods)up to 10,000 rpm regularly with stock internals.Originally posted by dannyboy77 View Postdoes look a steal but the torque seems low for what it is! is ft/lbs and Nm the same?? will that effect climbing performance?
For bucket loads of torque you'll need a high cubic inch, pushrod, cast iron engine.
