Originally posted by The Lovely Boyo
View Post
Need a Surf for offroading
Originally posted by mkiiisupraowner View Postsurely the bulk head plate isn,t going to say whether the surf has an elocker or lsd ... if it does then those japs are very thoughtful....=========
=SOLD UP!=
As was said above, check the vin plate to see whether it was fitted with an LSD.
...alternatively...I believe they put stickers on the back of the diff (although a 14 year old sticker may be a little hard to read) to indicate that as an LSD it requires different diff oil.
....the elocker thing came about as I have been reading a lot of forums (both uk and us) regarding the 3rd gen surfs and 4runners and came across some retrofit elocker details (e.g. http://yotatech.com/f2/e-locker-retr...rd-gen-151537/).
I have found a breakers with a surf with an LSD (or so he says).......however, he wants £350 just for the diff.....
Originally posted by Ava_Banana View Post....the elocker thing came about as I have been reading a lot of forums (both uk and us) regarding the 3rd gen surfs and 4runners and came across some retrofit elocker details (e.g. http://yotatech.com/f2/e-locker-retr...rd-gen-151537/).
In an old LSD the clutch plates will probably be worn out and need replacing. At which point you might as well toss an Aussie locker in there coz you'll have the diff in bits.......
But then you can just toss an Aussie locker in your current diff anyways and not bother risking buying a diff that may have the wrong ratio....
Or spend mega bucks on ARB air lockers, but they are very very good.......
Ahhh, endless fun and games........
