I have an electric supply to an outside building, it is 6mm SWA cable terminating at a junction box which then carries on through in 6mm T&E. to a CU unit.The supply is protected by a 40 amp MCB.
I wish to take a supply to another building.
Can I take a supply from the junction Box using 6mm SWA?
If so what is the best way to tap into the existing supply.ie. connector strip
or fit a new junction box, if so what type.
Thanks for any replies.
grin3:
