fuel consumption
  • fuel consumption
    has anyone else calculated their fuel consumption?
    i just did and my 3.0 ltr gets 17.57 miles per gallon.
    Is that about right for a 3 litre?
    Edit - Just read an old post and the aforementioned figure is terrible. Ill calculate it again tommorrow after a long run up to Sotland and back.
    Will post results
    私のホバークラフト は鰻が一杯です。
    Will post results
    i`m getting about 25 miles per gallon out of my 3ltr diesel surf.
    sigos85@hotmail.com
      My 2.4 does between 22 and 26 to the gallon
      My new ford ranger does 28-30
      www.cnpbetterhomes.co.uk
        I'm getting 22mpg with my 4.0.
          Avergae on my 3.0l is between 22-24mpg
            i get up too 30 out of my 2.4 you must be thrashing it if you get less than 20-25 and my 3.1 isuzu is nt a lot less than the surf if any you have got to get 25
              Here, use a couple of these...........,,,,,,,,,,,, no charge.
                I'm with Growler on 22-24. 30 sounds to be stretching it a bit, especially on a 2.4, unless you are counting the miles it does on the back of the AA recovery truck?
                  Me too I get around 20mpg.
                  Trust your Hound.
                    20 you must have a very heavy right foot i get high 20s perhaps if you all cleaned the 4-5 ton of 5hit and mud from under your trucks it would help and of course you skinflints could start using real diesel instead of lard and pig fat
                      20 mpg ha ha ha ha ha ha only from a pig fat burner
                        you are probably using 50% of your engines power just sucking the pig fat from your tanks
                          i was getting in the high 20's
                          but that air induction kit has taken that down to around 15 maybe less
                          eeeerrrrmmmm
                          thats on real diesel
                            dont under stand anything about air ind......ks...... things but at least someones on my side do you use hillbilly pig fat it may be that rather than the air wosname
                              sorry i should read the posts properly first your not a skinflint
