and another thing take the tractor wheels off and put the proper wheels back on that ll give you a few more mpg DERR
fuel consumption
Originally posted by steve s View Post20 you must have a very heavy right foot i get high 20s perhaps if you all cleaned the 4-5 ton of 5hit and mud from under your trucks it would help and of course you skinflints could start using real diesel instead of lard and pig fatOriginally posted by steve s View Post20 mpg ha ha ha ha ha ha only from a pig fat burnerOriginally posted by steve s View Postyou are probably using 50% of your engines power just sucking the pig fat from your tanksOriginally posted by steve s View Postdont under stand anything about air ind......ks...... things but at least someones on my side do you use hillbilly pig fat it may be that rather than the air wosnameOriginally posted by steve s View Postand another thing take the tractor wheels off and put the proper wheels back on that ll give you a few more mpg DERRhttps://www.facebook.com/groups/henpals/
has to be veg oil
any animal fat will kill ya truck (trans fats)
bigger wheels give ya a little more mpg
and i do use veg oil some times just coz its better than throwing it away
air induction kitts make the air go faster into ya engine helps the turbo runn better give a bit more power on take off
but i can just put the aire filter back in untill i want to use that bit more diesel for off roadingam not die lex sick its you that cant read mate
Originally posted by steve s View Post20 you must have a very heavy right foot i get high 20s perhaps if you all cleaned the 4-5 ton of 5hit and mud from under your trucks it would help and of course you skinflints could start using real diesel instead of lard and pig fatOriginally posted by steve s View Postand another thing take the tractor wheels off and put the proper wheels back on that ll give you a few more mpg DERROriginally posted by steve s View Post20 mpg ha ha ha ha ha ha only from a pig fat burnerand as for tractor tyres, mine are a factory fit option size so shouldn't make that much difference.
Are you sure you are doing your conversion from KM's to Miles correctly
Mine is standard too apart from an induction kit, and I dont go offroading.
Best I ever achieved was 25mpg but that was boring driving with an aim to see how much mpg I could get.
Calculated by filling to brim, setting tripmeter to zero and calculating over a few fillings.
MickTrust your Hound.
Bigger wheels give less mpg for several reasons. The stock gears are set up for standard wheels. Going bigger will make for less efficient gearing, and more importantly more weight further away from the rotational centre.
More weight further out from the axle means more power required to get the mass up to speed. Think of the old experiment you might have done in physics in school where you spin on an office chair and then pull your arms and legs in.Cutting steps in the roof of the world
Originally posted by Apache View PostBigger wheels give less mpg for several reasons. The stock gears are set up for standard wheels. Going bigger will make for less efficient gearing, and more importantly more weight further away from the rotational centre.
