I have been advised i should not run the power from the battery under the truck to the tow bar but instead run it inside the truck.
other than damaging the cable is there any other reason? if it was fully sleeved and above the chaise would there be any problems? just seams much easier to run it under the truck than taking lots of trim off inside to run it.
I want to fit some rear working lights etc so will need to run a thicker cable.
