Steering recall done
    Can someboy quickly explain what this recall thingy is about? does it only apply to secected vehicles?
    Thanks,
    Nissan Patrol for on-road, and a Land-Rover 110 shed for off-road :-)
      Read here...
      http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=20982
      There's always a Payback .... Ya won't ever see it comin tho !!!!
      Buncefield Burner
        I'll give you dollars to donuts that the oil leak is the rocker cover gasket.
          aha not 3rd gens then.
            It's recently had a new cylinder head and rocker cover gasket fitted.
            Roy
            When ya stop having fun, Ya start getting old
              How Do We Find Out If We Need Recall Doing?
                Check to see if your vin number is one in this link and if it is then give Toyota UK a ring, ill post the number up when i find it.
                http://dogandlemon.com/site/japanese...seno=RJ-1281-0
                Roy
                  Toyota UK Tel 01737 367600, that will get you straight through , quote them your Vin/Chassis number and i had to tell them the recall notice number (SR60635) and they pass your details on to Toyota Japan, they will let you know by recorded delivery if it needs to be done. Don't let Toyota UK fob you off, it is a safety recall and they have to sort it at there expence.
                  Roy
                  • #24
                    Had my recall work done today, at Benfield Toyota Leeds, as usuall a list of faults reported.
                    Weak anti freeze, £72.00
                    Oil leak, rocker cover
                    Oil half way up dipstick ?????
                    N/S/F cv boot distorted £56.31
                    Play in front wheel bearings £55.01
                    Free wash & vac out
                    Drives OK, don't pull to left any more so I'm HAPPY
                    • #25
                      Free wash & vac out
                      £56 for a cv boot and it was only distorted which probably means its not split at all.
                      • #26
                        Yeah, no splits only fitted boot 18 months ago to get thru MOT a bit too small, but it did the job, got a spare Roughtrax one in the garage, may fit it this weekend. But £72.00 for a coolant change is far too rich for me, another job for Saturday afters.
                        Where does the oil come to on your dipstick?
                        • #27
                          mine is up to the full mark.
                          I am wondering if the muppets had checked the atf dipstick if its halfway up
                          • #28
                            More work for Saturday then, will check it out in day light just to be sure.
                            half way between F&E will do till then, hope for good weather eh?
