Any ideas gents
  • Any ideas gents
    Whilst returning from a rather wet day in the lakes on Sunday that pretty little EMU check light lit up on the dash and the turbo cut out. Only lasted for a few moments and then returned to normal. At the time we were climbing quite a steep hill, but not hammering the old girl. It did the same thing for a few moments a few weeks back, when I was giving it a bit of hammer. Could this be a warning of things to come and if so what,
    Cheers guys, Spoggle
    I had the same problem on mine gradually got worse and worse untill it would not run. Took me months to sort it, turned out to be a loose earth on the gearbox. It can just be accessed from under the drivers front wheel arch, you can get about a quarter turn at a time on it.
    monstercreations.org.uk
      When the engine is under heavy load? Could just be the fuel filter needs changing. It goes into 'limp home' when its starved of fuel.
        I think you need to speak to Rod Hull, he will be able to advise.
          Dont think so! he fell off his ladder
            http://paranormal.about.com/cs/ancie.../ht/seance.htm
              Gregorian chant anyone? sing along if you know the words, if not hum
              The day i met you in the fo'castle locker
              I could'nt come me duff and you were chocka
              But never mind wings
              These foolish things remind me of you
              A sweaty sock beside an old french letter
              A dose of weeping sif that wont get better
              And when i pi$$ it stings
              Oh! sorry! wrong songsheet
                Fekking bird gets everywhere.
                Spoggle
                  Dont suppose you took a picture of the little sod did you, just so I have an idea what Im looking for.
                  Spoggle
                    Sure I've got a new filter some where. Just never got round to changing it, Must make the effort this weekend!!!! Cheers for the advice.
                    Spoggle
                      Spoggle
                      here you go!
                        Rod Hull's son is now doing a show in memory of his dad with Emu so keep an eye out on tv soon.
                        From what i have heard he's just as bad as he was when Rodder's was on tv
                          Spoggle
                          No I did'nt its real hard to get to espescialy if you have no body lift. But it is quite a big earth cable so easy to identify. If you climbe on top of the enging and look down the back I think its the left of the 2 top gearbox bolts.
                            At risk of repeating myself - check the fuel filter if you haven't done for a while.
                              At risk of repeating myself......
                              You took that risk, and you did.
