.....so i want to replace my tailgate window motor.. no problem. get another of ebay, whip the old one off (the teeth on the nylon cog are well knackered and it's been man-handled a few times so i bit the bullet and got another... ). The old motor "worked" but slipped and crunched etc.. you get the picture. so whip off the old one, stick on the new one and all should be good..... well, both the keyed switch on the tailgate and the one between the seats will only turn the motor one way... and that's up. won't switch the polarity to reverse the motor. i thought it was the "new" motor at first but it does the same on the old one too. up but not down. so issue is with the vehicle. i can't imagine both switches failed at the same time so i think those can be ruled out. there's a switch with a little roller on next to the window motor that looks like it tells the window when to stop on it's upward journey?... anyway, popped of the connectors and tested that too and it seems to be in working order. i can hear a relay when the switch is turned that seems to be in the back somewhere close to the tailgate but dunno where. i guess this needs locating and testing?.... anyway, if anyone has any other ideas or has experienced this themselves i'd be most grateful for a point in the right direction!
cheers
steve
