View Post
Rear Spoiler
lovely so wot size drill bits do i need?Originally posted by bandit77 View PostWell after pulling down the rear trim i was pretty confident i knew where to drill all the holes, as people have said the worst part was drilling the 30mm one for the 3rd brake light. phew it all went ok so i thought i'd show the results.
Originally posted by Maverick View PostDepends on where your roof rails are secured, and what type of spoiler you've got.
This is my set up, the spoiler is a roughtrax one.
Just trial fitted mine (Same spoiler) and my roofrails are in the way!!!
I fitted my rails as far back as possible so any loads would be over the L/C springs. A little fettling is gonna be requiered methinks.
I used a small drill bit to start with, i cant remember which size, was something like 3mm then used a 6.5 to drill the hole bigger... id masked over where i was going to drill so to help prevent the bit moving. to locate the hole i pressed from the inside out with one of those screwdrivers with a point (
lol i cant remember what there called) just to make a slight dent i could see from the outside. Then when it came to the large one i used the same smaller drills, but then used a 30mm cutter to get the cable through
- touched up the paintwork with a bit of touchup and then squeezed a bit of sillocone round when i located the spoiler for the last time.
(i did a couple of test fits to malke sure i was going in the right direction as i was drilling)Last edited by bandit77; 26 September 2008, 17:47.
yeh i think that'd look ok. or maybe even spray it satin black to match the window surround and other black bits on the car, the paints cheap from halfords and its really easy to get a good finish.Originally posted by breakdowntruck2 View Postthink i'm gonna be a bit diffrent and leave mine black,i think a black spoiler will look ok on green??
oh i dunno...............they look weird under the bonnet, with ...now what are they called..........oh yes, spark plugsOriginally posted by PDR View PostWhat! are you saying that Surfs don’t come as standard with a rear spoiler
Couldn’t imagine mne without one, it would look weird.
Non intercooled nothing.
